Field Maps Crashes When Selecting Feature in utility network
858
08-15-2024 06:03 AM
RG2
Hi everyone,
I recently migrated from Utility Network 6 (ArcGIS 11.2/Pro 3.1) to Utility Network 7 (ArcGIS 11.3/Pro 3.3). In the new setup, Field Maps (Android version 24.2.1, build 1510) works fine when the Utility Network layer is not included (though I lose trace capabilities). However, when I add the Utility Network layer and select a single feature, Field Maps crashes instantly without any error message—it just closes.
Interestingly, everything works as expected in both ArcGIS Pro and the web map environment. The issue only seems to occur within Field Maps.
these are the last lines of Field Maps log:
Thu Aug 15 16:00:22 GMT+03:00 2024 : [DEBUG (error)] - Uncaught exception!
com.esri.arcgisruntime.ArcGISRuntimeException: Invalid argument.: Unsupported Utility Network schema version
at com.esri.arcgisruntime.internal.loadable.c.getLoadError(Unknown Source:10)
at com.esr
Invalid argument.
Thu Aug 15 16:00:20 GMT+03:00 2024 : [APP LIFECYCLE] - Application asked to trim memory, level :: 10
Thu Aug 15 16:00:05 GMT+03:00 2024 : [GEOTRIGGERS] - Geotrigger count: 0
Thu Aug 15 16:00:04 GMT+03:00 2024 : [URLSCHEME] - Updating content uri handler: null to com.esri.fieldmaps.n6@e353cd8
Thu Aug 15 16:00:04 GMT+03:00 2024 : [URLSCHEME] - Updating Map handler: null to com.esri.fieldmaps.n6@e353cd8
Thu Aug 15 16:00:04 GMT+03:00 2024 : [URLSCHEME] - Updating content uri handler: l5.g3@6bc1573 to null
Thu Aug 15 16:00:04 GMT+03:00 2024 : [SNAPPING] - NOT activating snapping because not editing any features yet or it's disabled
RG2
