Field Maps Capabilities Issue
1314
11-17-2024 02:01 PM
IanHuerta
Currently I am trying to collect points with Esri Field Maps but my map is in read only mode. And I've gone and enabled editing I'm certain but it still will not let me place points from the cell phone.
Tags (3)
Eugene_Adkins
If your feature class is z aware make sure the feature service you created is also z aware. If it is not, you will not be able to create a feature. Here’s some documentation incase this applies to your situation.
KerriRasmussen
Hi Ian, good morning. In addition to what Eugene said, if you made changes to the settings of your layers (from read-only to editable) did you also open you map and resave the map? If you make any changes to the layer settings or schema you should open the map and save the map as well so those changes will be reflected in the map.
Debert
Do you see the blue circle (+ sign) in the lower right hand corner of your Field Maps/Map screen?
I am the GIS Coordinator for Iowa Regional Utilities Association.
Find me on Linkedin.
IanHuerta
Thanks guys, got a lead from a classmate, and it turns out the solution was to re-upload my feature layer, and go from there.
