Field Maps calculate acres of new feature
1654
08-04-2022 10:19 AM
MacLeanR
Is it possible to return the area of a new feature in acres to a field as the feature is being created?  I've been trying to accomplish this with:
return round(AreaGeodetic($feature, 'acres'),2)
It doesn't return anything on feature creation or editing of an existing feature.  Thanks for any help!
-Rich
JohannesLindner
Is your data in the right coordinate system? From AreaGeodetic:
Support is limited to geometries with a Web Mercator (wkid 3857) or a WGS 84 (wkid 4326) spatial reference.
Does it work if you use Area instead?
Have a great day!
Johannes
MacLeanR
The data is in WGS 84.  Using Area had the same results.
RhettZufelt
MVP Notable Contributor
Interesting.  Tried to test with round(Area($feature, 'acres'),2) and is working, BUT, only if I add the vertices correctly.  If I create a polygon in a counter clockwise direction, the area reports as negative, if I add points in clockwise direction, they are positive units.  ??????
R_
