Field Maps and True North
1066
12-03-2021 07:31 AM
JoshSmithWCWD
We've recently switched from Collector to Field Maps. Some of our field workers have pointed out that navigating to features is difficult when they are holding their iPads horizontally or in landscape. We've discovered that the iPad is using the top side (side of the iPad with the camera) as true north no matter what position the iPad is in. This is fine when using the iPad vertically, but it switches the map around when in landscape. We didn't see this behavior in Collector as it recognized which position the iPad was being held in. I'm wondering if anyone else has had this issue and if there is a fix or workaround for it.
Thanks in advance for your help!
