Field map data not syncing to SDE
902
06-25-2025 05:08 AM
Nicauldron
Hi there
I have set up a Fieldmap which is enabled for offline use.
A field worker went and added some photos to an editable layer and synced the map afterwards.
However, the data is showing in his map but nowhere else. I cannot see anything in the SDE layer.
What is going on here?
Tags (3)
George_Thompson
Esri Notable Contributor
What version did they user sync to?
What version are you connected to in the Enterprise Geodatabase?
It sounds like a reconcile / post may be needed to get the states of the data the same (i.e., be able to see the edits).
--- George T.
Nicauldron
I have Traditional versioning enabled, with one version "for each downloaded map".
Nicauldron
Okay - I think I have found the isue. Somehow the settings in Pro have changed to the grey boxes instead of ticks where it says versioning and track editors.
I think this happens every time a new layer is added to the dataset, annoyingly. So need to remember to switch them on every time.
The real question is: If I turn those settings on now, what will happen with the images stuck in version limbo??
