Field Maps flickering, showing 'no portal connection' and other odd behaviour
461
5
06-26-2025 04:31 AM
DataOfficer
Since the ArcGIS June update last night, we are seeing some odd behaviour in Field Maps (so far checked on android devices running version 25.1.0, build 1529).
We are seeing some flickering or flashing of maps, occasional 'no portal connection' messages and general instability. Is anyone else seeing this behaviour?
No portal connection messageNo portal connection message
NicolaRiordan
Yes we are also having issues today with Field Maps and also ArcGIS Online in general - gateway timeouts when logging in, attribute tables not loading, layers not loading for some users on Field Maps, and just being very slow in general
DataOfficer
Some further odd behaviour a user has experienced whilst trying to load a map.
Unable to openUnable to open
MeganHaleGIS
We are also having issues with AGOL/Field Maps this morning. Random layers will not load in FM or on the new AGOL overview pages. When refreshing the page in AGOL or reloading the map on FM, the layers that previously had errors will load fine and different layers will not load. We cannot use FM this morning due to this. I hope ESRI resolves these issues quickly so we can resume work.
AmeWunderle
We are also seeing odd behaviour, layers not loading in Field Maps on maps working yesterday. Basemap gallery not available. Offline areas cannot be downloaded.
Offline areas that were downloaded earlier this month have accessible/viewable layers still.
StephanieW
This is likely related to the performance issues indicated at https://status.arcgis.com/, Esri is working towards a resolution as quickly as possible. If you are able to create a Tech Support case, your account will be able to be attached so you are notified about updates. http://support.esri.com/en-us/contact
