Field map app sync shows success, but data not updating to feature Layer
2743
11-09-2023 10:47 PM
mukecz1
Hi guys,
I have a strange issue. I created a feature layer that is registered with the Oracle database and enabled its offline functionality. Everything seems fine: I can create an offline area, draw a point, and submit data. Even the sync on the Field Maps app occurs without any error messages. Additionally, I checked the ArcGIS server job log of the sync tool, and it shows 'esriJobSucceeded', indicating success.
The full response of 'out_result' is:
 "paramName": "out_result",
 "dataType": "GPString",
 "value": {
  "transportType": "esriTransportTypeUrl",
  "responseType": "esriReplicaResponseTypeNoEdits",
  "replicaServerGen": 5,
  "replicaName": "Ags_Fs",
  "replicaID": "30f2e7ba-6f5b-466b-9858-ca8f36f51dab",
  "targetType": "client",
  "resultUrl": ""
However, the data does not update to the feature layer, and there is no data in the table.
I suspect the issue might be due to the projection on the Field Maps being different from that of the feature layer, as we use EPSG:28355.
But if it were a projection issue, shouldn't it display an error message?
Has anyone else experienced a similar issue?
Tags (3)
Parth_Ent
Any update on this? Was this resolved? I am facing the same issue. Any suggestion would be much appreciated.
Regards
PiotrCienin
Do You know solution ? I have the same problem now...
RoggerCorrea
Hi ESRI.
We are currently experiencing a very similar issue.
We figured out that we have a corrupted feature class.
We are currently getting success response from the ESRI server, but no syncs are happening.
Our servers are ESRI 10.8 and 11.
The issue happen in both. We get no logs on the server that allow us to detect any issues. We know the changes on the layer ID 7 are not syncing, but this is the server response:
Header:
Date: Tue, 25 Feb 2025 01:34:51 GMT
Content-Type: text/plain;charset=UTF-8
Content-Length: 372
Connection: keep-alive
Set-Cookie: AWSALBTG=T7z9zGCM1bwFRljar6i2LCu/g0boKGnnPQNAEIMSfyC1lHMRGf73GyXZuDCaujNagHLA/9XhPAnVIENSaTdANEJYUIjMBW1nqVVy384UNaa2wY/ZihEQGoV0Gdru4jAvYcYL9lmHcLTg5AZKuLFqhTuHn9ltMOf+d4X4UFTM5+tUE4R8Ie0=; Expires=Tue, 04 Mar 2025 01:34:50 GMT; Path=/
Set-Cookie: AWSALBTGCORS=T7z9zGCM1bwFRljar6i2LCu/g0boKGnnPQNAEIMSfyC1lHMRGf73GyXZuDCaujNagHLA/9XhPAnVIENSaTdANEJYUIjMBW1nqVVy384UNaa2wY/ZihEQGoV0Gdru4jAvYcYL9lmHcLTg5AZKuLFqhTuHn9ltMOf+d4X4UFTM5+tUE4R8Ie0=; Expires=Tue, 04 Mar 2025 01:34:50 GMT; Path=/; SameSite=None; Secure
Set-Cookie: AWSALB=DGoZISnRrS+/2FjEKBbuGAbdXOm5R2lFEhMqqrKDIrrDGvAyorux3pTM8etOyqZd9cdfsFNQgWTgu1qFbFc+fVP6k6FFy0SIQ6KUHyRqHIF7WqqZ4lIFSAwXMPq0; Expires=Tue, 04 Mar 2025 01:34:50 GMT; Path=/
Set-Cookie: AWSALBCORS=DGoZISnRrS+/2FjEKBbuGAbdXOm5R2lFEhMqqrKDIrrDGvAyorux3pTM8etOyqZd9cdfsFNQgWTgu1qFbFc+fVP6k6FFy0SIQ6KUHyRqHIF7WqqZ4lIFSAwXMPq0; Expires=Tue, 04 Mar 2025 01:34:50 GMT; Path=/; SameSite=None; Secure
X-Content-Type-Options: nosniff
X-XSS-Protection: 1; mode=block
Vary: Origin
Cache-Control: max-age=0,must-revalidate
Server:
ETag: "b3439c0a"
Content-Encoding: gzip
Body: {"transportType":"esriTransportTypeUrl","responseType":"esriReplicaResponseTypeNoEdits","layerServerGens":[{"id":0,"serverGen":1740447279173},{"id":1,"serverGen":1740447279173},{"id":2,"serverGen":1740447279173},{"id":3,"serverGen":1740447279173},{"id":4,"serverGen":1740447279173},{"id":5,"serverGen":1740447279173},{"id":6,"serverGen":1740447279173},{"id":7,"serverGen":1740447279173},{"id":8,"serverGen":1740447279173},{"id":9,"serverGen":1740447279173},{"id":10,"serverGen":1740447279173},{"id":11,"serverGen":1740447279173},{"id":12,"serverGen":1740447279173},{"id":13,"serverGen":1740447279173},{"id":14,"serverGen":1740447279173},{"id":15,"serverGen":1740447279173},{"id":16,"serverGen":1740447279173},{"id":17,"serverGen":1740447279173},{"id":18,"serverGen":1740447279173},{"id":19,"serverGen":1740447279173},{"id":20,"serverGen":1740447279173},{"id":21,"serverGen":1740447279173},{"id":22,"serverGen":1740447279173},{"id":23,"serverGen":1740447279173},{"id":24,"serverGen":1740447279173},{"id":25,"serverGen":1740447279173},{"id":26,"serverGen":1740447279173},{"id":27,"serverGen":1740447279173},{"id":28,"serverGen":1740447279173},{"id":29,"serverGen":1740447279173},{"id":30,"serverGen":1740447279173},{"id":31,"serverGen":1740447279173},{"id":32,"serverGen":1740447279173},{"id":33,"serverGen":1740447279173},{"id":34,"serverGen":1740447279173},{"id":35,"serverGen":1740447279173},{"id":36,"serverGen":1740447279173},{"id":37,"serverGen":1740447279173},{"id":38,"serverGen":1740447279173},{"id":39,"serverGen":1740447279173},{"id":45,"serverGen":1740447279173},{"id":50,"serverGen":1740447279173},{"id":55,"serverGen":1740447279173},{"id":60,"serverGen":1740447279173}],"replicaName":"Ags_Fs_1740446506100","replicaID":"5bef2cd6-ced3-44e4-aa5d-b419cbe11c00","targetType":"client","resultUrl":"","submissionTime":1740447186000,"lastUpdatedTime":1740447287000,"status":"Completed"}
Raw response:
HTTP/1.1 200 OK
Content-Length: 372
Vary: Origin
Server:
ETag: "b3439c0a"
Our solution was to create a copy of the corrupted FC and not use the corrupted one. But the server is not detecting the syncing failure, or at least the sync is not flowing into the database and we are not getting anything in the server  logs, or is there any way to find that out?.
