Fetch an attribute from underlying data layer in Field Maps
1505
08-14-2024 10:14 AM
AshlieHildebrand
I am trying to auto populate an attribute field in a layer in Field Maps forms using Arcade. I am placing a point on top of an existing point in Field Maps and I want to auto populate a field from the existing point layer to the feature I just created on top of it. I am using snapping, so they should be exact.  I am using the following calculation in forms and it will return "Null" but not the attribute from the underlying layer, which is what I want.
What am I doing wrong.....I used the code from the "Common calculated expressions for ArcGIS Field Maps" document.
KeizzyA
There could be a number of things but I would like to rule something out.
The second line what if you wrote it like this:
var SiteID = First(Intersects($feature, SiteIDs))
Hope it was that simple!
AshlieHildebrand
Nope that didn't make a difference...
Update:
The below code works for a polygon feature that is the underlying feature but it gives me "No Data" for a point feature and I am using snapping. Thoughts....
var SiteIDs = FeatureSetByName($map,'Polygon Test',['SiteID'])
if (!IsEmpty(SiteID)) {
  return SiteID['SiteID']
} else {
  return "No Data"
