Error Syncing Template Symbology in Field Maps
203
10-07-2025 01:56 PM
g_maps
My template symbology in field maps disappeared halfway through the creation of a form for a point layer and now I have no option anywhere to update template symbology and sync my templates. When I go to drop a point in the field map now I see the same transparent point for all categories instead of my default symbology (shown below).
This happened once before during my configuration of the field map, but a splash screen opened when I entered the template editor asking me to update the templates. That splash screen hasn't popped up again and my template symbology is stuck. This also seems to be affecting field calculations in my form.
Any insight on this matter would be greatly appreciated, thank you!
g_maps
Hi Emily,
Thank you for your response!
I was actually coming back today to say that if you reset to show location only, sync the template in field maps, then go back and choose your default visualization in your web map the sync option will appear again in field maps and reset the symbology.
However, next time I will keep your suggestion in mind, seems like that would be a faster solution.
EmilyGeo
Can you try making a change to in the Styles pane in Map Viewer?
After you make changes to the style such as adding or moving a category to another group, you should see the option to Sync the templates appear in the template window.
g_maps
Hi Emily,
