Error Downloading data to device in Field Maps
1557
02-26-2021 08:15 AM
vijaybadugu
I am facing the issue for offline data. it was working fine and suddenly throwing the issue.
I am using ArcGIS Field Maps IOS Device with arcGIS Enterprise 10.8
Error executing tool. CreateFeatureServiceReplica Job ID: j14edc17dff6842f2b73524a60c0919e7 : ErrorMsg@SyncGPService:{"code":400,"description":"Failed to create replica."} Failed to execute (Create Feature Service Replica). System/SyncTools.GPServer Table not registered [main.stands]. System/SyncTools.GPServer
In ArcGIS Server Logs
In Device Logs,
create replica., NSURL= responseJSON={ error = { code = 400; description = "Failed to create replica."; }; lastUpdatedTime = 1614295246000; replicaName = ""; resultUrl = ""; status = Failed; submissionTime = 1614295236000; }, NS
ColinLawrence
Hi @vijaybadugu ,
Have you tried creating a replica outside of Field Maps (at REST or using another app)? This could help determine if its a service or app issue.
Have you tried using preplanned offline areas?
Regards,
Colin
Regards,
Colin
WilliamPérezC
Hi guys I have the same error, any solution?
