Elevation Attribute Population in Field
12446
22
01-27-2021 05:56 AM
CarsonG
Is there a way in field maps to have an attribute for elevation populate automatically after a point has been collected?
I would like the elevation attribute to populate when a feature is newly collected or updated.
When I published the data as a service for use in the field, the data had a vertical coordinate system.
When I try to calculate the Z value in ArcGIS Online using Arcade Calculator using Geometry($feature).z, no results are returned.
If I export the data collected from the field to a GDB, the data has a Z value and can be populated using the calculate geometry tool in ArcMap. The data however no longer has a vertical coordinate system assigned to it.
KevinBurke
Thank you @CarsonG
CarsonG
Hi Kevin,
I tried going the route you previously discussed and using arcade to calculate the Z value in the current map viewer. I then switched over to the map viewer beta, the values are blank. Additionally, values that I had in the field before have also been turned to blanks.
KevinBurke
Hi @CarsonG
Would you be able to share a copy of your map with me to test out on my end? If so, please share the map/services with a group and invite the ArcGISFieldMaps users into it.
Thank you
-Kevin
CarsonG
I will have to create a test set of data to do so. Once I have, I will let you know and share to the the group specified.
KevinBurke
Thank you @CarsonG
CarsonG
Hello Kevin,
I finally have some time to do the testing I wanted to do. I sent an invite to the user specified above. The group is called Elevation Field Maps Testing.
I am going to collect some test points in order to test the Arcade elevation calculation with the Trimble Mobile Manager GNSS output frame set to WGS84 and GEOID set to Geoid18. Additionally, I have created another Location Profile in Field Maps for this testing as follows;
GNSS coordinate System
GCS WGS 1984
4326
Map coordinate system
WGS 1984 Web Mercator Auxiliary Sphere
3857
Thanks!
CarsonG
Hello @KevinBurke
To give an update, I created a web map in which all data is in the same Coordinate System.
WGS 84 UTM Zone 17 N
Trimble Mobile Manager is set to;
Output Frame = WGS1984(current)
GEOID = Geoid18
Field Maps Location Profile is set to;
GCS WGS 1984
4326
Map Coordinate System is set to;
WGS 1984 UTM Zone 17N
32617
After collecting some test points in the field, I attempted to run Arcade and calculate the Z value for the Elevation attribute field. No results were produced. I then opened the map in the Beta Viewer and tried to see if the Z values were displaying. They were not. I know the correct Z value is being collected because when I open the data in ArcPro, I can calculate the Elevation field and produce the correct Z value.
This is not the solution I need, as it would still be beneficial if x, y, and z fields could be calculated on the fly inside Field Maps.
KevinBurke
Thank you for the information @CarsonG
Just for clarification, the map includes a point layer that is Z-enabled, however when you attempt to use arcade to calculate the z value into a field using something like geometry($feature).z, nothing is populated. Is that correct?
In ArcGIS Pro, are you using Calculate Geometry to display the Z value?
Would you be able to share that map with me with some test data?
Thank you
-Kevin
CarsonG
Yes, the point layer is Z enabled. When I used Arcade to calculate values into the elevation field, nothing is populated. In Pro I used the Calculate Geometry to display a Z value.
I sent an invite to a group called ElevationFieldMapsTesting to the user "ArcGISFieldMaps" you specified previously.
Kyle_LocGov
PlutoGIS, I'm having similar issues. Are you still checking this account and if so can I pick your brain?
