Dispatching Field Maps Tasks
6411
25
10-20-2025 06:28 PM
MDBowser
With ArcGIS Workforce retiring, and replaced with Tasks within the Field Maps App - what are we supposed to provide for our dispatchers for Task Assignment?!  Is there an equivalent to Workforce for this?  The documentation on this is super limited at this point.
I understand there is the Field Maps Designer for deploying this, however, this is for the technical GIS staff to deploy.  The solution I require is something for dispatchers to assign and manage work assignments (tasks) for mobile crews.
Did Esri just abandon this component of ArcGIS Workforce and require users to develop it on their own?
Anyone in the know, please help!
Cheers,
Mike
LizArmstrong
Thank you for sharing. Would you mind sharing your use cases for why assigning tasks to multiple workers would be helpful?
Laura
by MVP Regular Contributor
One example of how we're currently using tasks is at our city cemetery. We have two full-time field workers who often work together on assignments. When new tasks come up, they're typically not specific to one individual, so we end up leaving them marked as "unassigned"—which, frankly, gets frustrating.
It would be much more efficient if we could assign tasks to both workers simultaneously. That way, instead of having them filter their Field Maps for unassigned tasks, they could just see what's relevant to them directly.
ChrisDunn1
Hi @Laura,
While there is no way to, for instance, pick multiple users from a drop-down list as the assignee, it is possible to assign tasks to multiple assignees with some changes to the task layer and the task configuration.
Essentially, you can create a field that contains all of the assignee names, and use a task filter that looks for the current user’s username anywhere in the field. To do it:
- Create a text field called “all_assignees” or similar
- When creating or assigning tasks, populate that field with the names of all mobile workers who need to see the task, i.e. “mobile_worker_1, mobile_worker_2, mobile_worker_4” etc.
Think about how this should work from the dispatching side. Maybe you use templates for the different options, maybe you use calculated values based on a “Crew” field so the dispatcher can pick the crew and the crew usernames are automatically added to the field. Maybe you use arcade to intersect with a site boundary and assign the workers that way. There are a lot of ways to automate creation of this list to keep dispatchers from having to enter names manually, it will really depend on your workflow and data.
- Create your task filter. You could edit the “Assigned to Me” filter, or create a new one. The top filter in the list will be the default filter when opening the map. Use the expression:
all_assignees like ‘%CURRENT_USER%’​
Note that `all_assignees` is the example field name I used above, so use whatever field you created to hold the list of names.
This will result in any person listed in the field seeing the task in their list when they open the app
After that, any additional changes to the tasks configuration will depend on how you want things to work. Would the workers still pick up tasks individually? Or would they always tackle them as a team? You may want to adjust the “pickup” action accordingly to only change the status and not the assignee.
I’m happy to go over things in more detail if this looks like a solution that would work for you.
Chris
Debert
For me, having a handful of distribution techs that cover a very large area- and not knowing which tech will be in the area first- would be a reason not a assign the task to a single person. In fact, most task would be left open to the tech that arrives or is closest to the task area.
I am the GIS Coordinator for Iowa Regional Utilities Association.
Find me on Linkedin.
RoshanPalikhe1
In Workforce, I can create an assignment by searching an address and the location gets auto populated.
I want to do the same in Field Maps Tasks — create a feature by searching an address so the location is automatically filled.
How can I do this?
Thanks.
Pam_Kavaleski
I added a Property Owner field and a Location field and then I used an Arcade Expression to pull the data from the underlying parcel.
However, it is not as clean as I think you would like it to be. In my case, the user has to first place the task icon in the parcel before it will pull in the data.
RoshanPalikhe1
Thanks, that’s helpful.
I’m trying to avoid manually placing the point and achieve something like Workforce, but it looks like that isn’t possible. Your Arcade approach for auto-filling attributes is still useful
RoshanPalikhe1
LizArmstrong
We do not currently have a video demo illustrating managing tasks with the Instant Apps Manager template but we intend to do a Tips from the Team video on that. Meanwhile, I can highlight the key functionality in the Instant Apps Manager template that Workforce also had:
  • Ability to create, edit (including assign), and delete individual tasks
  • Ability to batch create, edit (including assign), and delete tasks
  • Ability to see a map and a table view of the tasks
  • Ability to sort and filter tasks based on various criteria like due date, assignee, etc.
If you have other dispatching requirements, I'm happy to take those down and share it with the teams that build Instant Apps and Experience Builder.
Tasks does not currently support being able to assign a single task to multiple workers. Would you mind sharing your use case for that and I can log it as an enhancement request? I'm not sure if it would fit your scenario but there is a way to have an unassigned task list where workers can pick up work.
MDBowser
Thank you for the information.
I have been pouring over the documentation trying to understand how this relates to the Workforce functionality that is being deprecated and I am struggling to understand what functionality exists vs not.  In workforce I can assign a task to a mobile worker - this is linked to the data collection map for that specific assignment.  How does this work with Tasks now?  If my mobile worker has 4 different data collection maps in field maps, how does the assigned task steer them to the correct map to begin data collection?  And on this note, how does one expose all these tasks for a dispatcher to pick from?  From what I can see here - this functionality is lost as this is all based on one data collection map?
The challenge we have here is we literally just pitched workforce functionality for our org to get buy in as a solution for work order management for field data collection - and they loved the functionality.  Now we have to retract that, which is pretty frustrating. So I need to flush out what we can and can not do with this new paradigm.   Perhaps you have a functionality matrix between workforce vs tasks you can share?
Thank you for your help.
