Disable New Feature Collection While Allowing Attribute Editing
2348
05-19-2022 11:47 AM
CassHonebein2
I have a field map set up where I'd like to allow users to edit the attributes of a road layer but not add any additional road features. I have not been able to find a setting to disable adding features without also disabling updating attributes. I tried the settings page for my hosted feature layer, under "What Kind of Editing Is Allowed?", but when you uncheck "Add", "Update" also becomes unchecked.
Is there a way to prevent users from adding or deleting features, but allow them to update the attributes of existing features in Field Maps?
by Anonymous User
Not applicable
What do you see when you un-check "Add"? It should look like this:
It's disabled and checked because you must select one of the 3 options
by Anonymous User
Not applicable
CassHonebein2
Thank you Aaron. I didn't notice that the Update was still checked when it got greyed out. One of those things that's super obvious now that I see it. Thanks for your help!
