control of $feature when using Test in Arcade editor
4821
10
11-17-2022 03:34 AM
JB_SEPA
This maybe a "Doh" moment but I've been staring at this for so long now.
In AGOL Field Map, in a calculated expression, is it possible to control which $Feature the "Test" button runs the code on? It defaults to the first record and field in the table, in my case 733mm of rainfall. I would like to test the code on different row in the table. How can I do this?
Thanks for any help.
Jonathan
RhettZufelt
MVP Notable Contributor
I don't see it anymore, and they also removed it from the Arcade Playground making it a pretty much useless utility now.
R_
