Connect external camera
1080
05-09-2022 06:59 PM
AmandaAngove
Do you know if it is possible to connect and external high res camera with Field Maps?
Thank you
Mandy
RobertBorchert
Honored Contributor
If your DSLR has a mini USB port on it you should be able to connect if via Lightning to USB to an iPhone
some Wi-fi enabled DSLR cameras should be able to as well.
In the App store look for
DSLR Controller
