Conditional Visibility if another field is blank
877
01-25-2023 12:20 PM
JasonCyphers
Want to create an expression that only makes field B visible if field A is blank/null/empty.
Is that possible?  If so, what would the expression look like?
jcarlson
When you configure your form, the simple expression builder should be able to handle it.
And in Arcade, that's:
IsEmpty($feature["some_field"])
- Josh Carlson
Kendall County GIS
