Conditional Field List
3364
03-05-2021 02:30 PM
HermanLouie1
I wondering if there is a way within Field Maps or AGOL to create a Conditional Field selection List
ie Brand, Model
if is select "Brand A" in "Brand Field Name" I want to show a limited selection list in "Model Field Name"
I know I could setup up a new field for every brand "ie Models for Brand A"  and use Conditional Visibility and "Brand Field Name" or use subtype, is there a better way?
Subtype Method
Can you limit the drop-down list of domain values displayed in one field based on a value provided in a previous field using Arcade for Field Maps?
by Anonymous User
Not applicable
This is not supported today but is on the near-term road-map for Field Maps. ArcGIS Pro allows you to configure Contingent Values which is what you are asking about. Soon, these will be supported in hosted feature services and the ArcGIS runtime, then Field Maps can consume them and use them in forms.
by Anonymous User
Not applicable
yockee
This is November 2024. Has it been supported now ? thanks
