Collect Sensor data
1852
02-16-2022 06:00 AM
AJM
Is it possible to record an external NMEA sensor along with GPS coordinated in Field Maps or Collector?
I want to have the depth measurement, from a sensor that will output a NMEA sentence, stored as an attribute, as I log points at a 1 second interval. I was able to do this on my old Trimble using Terasync, but am looking to upgrade units and move to using Field Maps or Collector.
Thanks
bsneller_esrinederland
https://doc.arcgis.com/en/field-maps/faq/faq.htm but depends on your GPS en OS which specific system is supported
DanielleMRadomile
I am running into a similar problem/question with an external sensor. Were you able to complete this workflow using Field Maps?
AJM
No, I have not made the upgrade yet, so I have not try to get it to work.
JasonSmith3
Ever upgrade and test this out?
