Coded Value Domains based on SubTypes not showing for fields
11496
10
03-22-2022 07:40 AM
KeithGanzenmuller
I have an infrastructure related featureclass that has heights and widths which are doubles. They have coded value domains of type double that change depending on subtype.
I am trying to use the featureclass in Field Maps. Ideally the employee would pick a value, in this case of type Double, from a dropdown list of acceptable values from the coded value domain.
Usually works great for text fields but doesn't seem to work with numeric (double). I get an input box of type Number - Double that requires direct input with no way to set a dropdown list. Seems to do the same when editing in the new map viewer. Don't think I've ever run across this before. Are dropdown lists not available for non-text coded domains?
The domains based on the subtypes do seem to be present in the published service (ArcGIS Server) as shown by this partial copy, the subtype field is "Type"
Types:ID: 1
Domains:
  • TYPE:
    Inherited
  • MATERIAL:
    Inherited
  • InspCompl:
    Inherited
  • Culvert_Width:
    Coded Values: [3: 3 ft] , [4: 4 ft] , [5: 5 ft] , ...7 more...
  • Culvert_Height:
    Coded Values: [3: 3 ft] , [4: 4 ft] , [5: 5 ft] , ...9 more...
  • Culvert_Material:
    Inherited
  • Culvert_Condition:
    Inherited
  • End_Treatment:
    Inherited
Name: Arch - RCP
Domains:
  • TYPE:
    Inherited
  • MATERIAL:
    Inherited
  • InspCompl:
    Inherited
  • Culvert_Width:
    Coded Values: [18: 18 in] , [22: 22 in] , [26: 26 in] , ...14 more...
  • Culvert_Height:
    Coded Values: [11: 11 in] , [13.5: 13 1/2 In] , [15.5: 15 1/2 in] , ...14 more...
  • Culvert_Material:
    Inherited
    Inherited
  • End_Treatment:
    Inherited
Name: Arch - CMP
    Domains:
    • TYPE:
      Inherited
    • MATERIAL:
      Inherited
    • InspCompl:
      Inherited
    • Culvert_Width:
      Coded Values: [18: 18 in] , [22: 22 in] , [25: 25 in] , ...10 more...
    • Culvert_Height:
      Coded Values: [11: 11 in] , [13: 13 in] , [16: 16 in] , ...10 more...
    • Culvert_Material:
      Inherited
      Inherited
    • End_Treatment:
      Inherited
Any ideas greatly appreciated
CoMAGOL_ADMINISTRATOR
Any updates.
I have a subtyped feature class, the domain code value is different between subtype filed.
as put this out for editing in the field, want to also change the colour to show gray when the asset has been edited. It seems still not able to do that in the field maps.
I am using Portal 10.9.1, Will audit the asset in the FieldMaps only.
