Cannot enter decimal value in double data type field
4270
07-19-2021 06:44 AM
ChrisShaffer
I created a hosted feature class and added double data type fields to store decimal values. When I attempt to enter a value in Field Maps, the keypad does not show a decimal point key or button. Only numbers from 0-9. Min/max values are set to 0 and 50.1. I want to enter values like 12.5. When I enter three digits like 125 it won't accept it because it is out of range.
by Anonymous User
Not applicable
It looks like you are using an Android device. You may need to change the keyboard that your phone is using. This what it looks like on my Pixel 4 with Android 11.X and the Gboard:
by Anonymous User
Not applicable
ChrisShaffer
Wonderful! Installing the Gboard app and setting it to the default keyboard worked. Unfortunately, the same can't be said on an iPhone X version 14.6. Still having this problem. Anyone else experience this?
ChrisShaffer
Figured it out on iPhone X! The decimal point key is there.
kawakawa4
Hi Chris, how did you you get the decimal point key on your iPhone please?
