Basemap does not have a valid spatial reference
704
02-25-2026 11:37 PM
PHATHEKATENGIMFENE
In ArcGIS Field Maps 24.1.3, I am unable to switch the basemap, despite both the map and basemap sharing the same spatial reference. When attempting to switch, I receive the following error message:
"The basemap does not have a valid spatial reference."
JavierML
Hi @PHATHEKATENGIMFENE
can you share more information about the case? Is the basemap a custom one or a default one? What Coordinate System do the layers have?
PHATHEKATENGIMFENE
@JavierML   The basemap is a custom basemap and the layers are using WGS_1984_Transverse_Mercator.
JavierML
Hi @PHATHEKATENGIMFENE ,
sorry for not answering on the weekend.
I see something strange in your screenshots. Your projected coordinate system looks as if it was "Custom". Normally, the projected coordinated system has a defined name, ID and Authority (normally EPSG). Yours doesn't.
It isn't my area of expertise, but I would guess that, after an update or transfering the layer too many times, the Coordinated System is not correctly recognised anymore. Could you try the following:
  • Use the project tool to create a new layer with a valid Coordinated Sytem (you could try EPSG:3395, EPSG:4326, EPSG:4258,EPSG:3857 or even the 4148 you currently have)
    (WGS 1984 World Mercator) and then upload the layers to Field Maps. You can even try and converting it once again into
  • If you can't reproject, use the tool Define Projection to set the Coordinating System to EPSG:4148 and then try to upload it.
Tell me if it worked or not at the end
JonathanLebowitz
Hello. ArcGIS Field Maps will not recognize a coordinate system that is missing a WKID (i.e., authority is set to custom).
