ArcGIS Pro data export results in consolidation to single location
2237
13
11-21-2024 11:51 AM
JasonWeis_Westwood
This week, after updating ArcGIS Pro to version 3.4.0, when I attempt to export a selection of points collected with Field Maps in an ArcGIS Online hosted feature layer to a file geodatabase feature class, all of the exported points show up in a single location (the location of one of the exported points).  This occurs with both a right-click on the layer name (with Data: Export Features), and also with starting directly from the Export Features geoprocessing tool. The other attributes appear to maintain their original values - it is simply the location that gets modified.
I have been using this workflow frequently in the past (exporting a subset of collected points to a project-specific geodatabase), and the points always exported to the correct location, even if specifying a new coordinate system. I did not notice this "consolidation" until this week, which just happens to coincide with my v3.4.0 update.
When I tested this with other ArcGIS Online point data that was NOT populated using Field Maps, the points exported correctly. Likewise, when exporting selected points from a local source (file geodatabase), the points also exported correctly.
I am attempting to find ArcGIS Pro installations within the organization that have not upgraded to 3.4.0 to see if it is version specific. Has anyone else encountered this issue?
Tags (1)
JesseCloutier
Esri Community Manager
Hi @JuanitaBorden, we appreciate you sharing that you're also experienced a potential bug with the broader Esri Community; however, Esri does not actively track software defects posted here. The official channel for investigating and validating bugs is Esri Technical Support. All customers experiencing a potential software bug should leverage technical support to report and investigate the issue—even when others have already reported the same experience.
By reporting bugs through technical support, Esri can better track the scope and impact of the issue across all our customers and better prioritize it with our product teams. Our teams can also investigate the issue more thoroughly to see if there is a solution, workaround, or patch to get you back up and running as soon as possible.
As a reminder, Esri Community is primarily a self-service support platform where Esri users can ask or answer each other’s questions, share feature requests, and collaborate to solve problems with GIS.
*Note that this is a scripted message prompted when posts allude to a potential product bug.
Jesse Cloutier
Community Manager, Engagement & Content
JasonWeis_Westwood
From another post: https://community.esri.com/t5/arcgis-pro-questions/problem-exporting-features-from-feature-service-t...
It sounds like a bug has been logged (BUG-000172816) and is being reviewed by Esri. A temporary workaround seems to involve disabling the export of attachments in the feature layer (Environments / uncheck Maintain Attachments).
Hopefully a 3.4.1 patch will be issued soon, since this is an important part of my workflow.
JasonWeis_Westwood
I was hopeful that one of the two patches that became available last week would fix this issue. However, after applying both patches (currently at v. 3.4.2), the issue persists.
gonzalad348
I too am experiencing this bug and I'm on Version 3.4.2.
Tags (1)
