ArcGIS Field Maps 25.2.0 release, all existing offline areas have disappeared
422
5
a month ago
CeBe
With the ArcGIS Field Maps 25.2.0 release, all existing offline areas have disappeared. It's likely because in the old version the offline areas were stored under: android/data/com.esri.fieldmaps/files/user@organisation_portalname, but in the new version they're now stored under android/data/com.esri.fieldmaps/files/user@organisation-portalname. (Hyphen instead of underscore) This is bad, very bad indeed... I can't expect hundreds of field workers to manually copy the data over. Will this stay like this or will it be changed back? How should I proceed?
Alex_Moore
Hi @CeBe ,
This is a known issue with the recent release that we are working on.
We sincerely apologize for the frustration this is causing. We understand that it’s affecting multiple users and disrupting daily workflows.
A possible workaround involves renaming the ArcGIS Field Maps directory on an affected device from the _portal to -portal naming pattern.
Example: [username]_portal to [username]-portal
If you haven't already done so, I strongly encourage you to reach out to Esri Technical Support, or your local distributor if you are outside of the United States.
Associate GIS Analyst
Esri Canada
JenFrazer_USFS_NR-GISS-IRIN
Thanks @CeBe for posting this.  What type and operating system android devices are you leveraging?  Curious if this is platform specific or will this hit all android devices?  I am part of an agency that uses a mix of devices.
CeBe
We are using from Android 12 to Android 16. Many different devices, all are effected.
JenniferTennant
Try putting it in airplane mode. CLose the app and restart a couple times. I notice my offline maps are only visible if I am truly without service.
agjackson1
It may not be just an Android problem! I'm having the same problem on my iPhone 14.  No offline areas show up when I tap on my map, but when I go to download a new area, my old offline areas show up!  BUT, that's only when I'm on wifi or have a strong cell signal - when I have little to absolutely no cell signal, none of my offline maps show up at all (& I obviously can't open my online map).  I have not tried the airplane mode trick & will, but I seriously hope that isn't the permanent "solution"!
