Arcade help
606
11-04-2025 06:52 AM
MichaelFettkether
I need some help with an arcade code. I have this:
var geom = Geometry($feature)
if (IsEmpty(geom)) {
  return null
  } else {
    return geom.Z
This returns a value in meters. Can a conversion be added to the code that converts it to feet?
I'm using a Leica Zeno FLX100 Plus and loading data directly into Field Maps.
KenBuja
MVP Esteemed Contributor
You can convert it like this
var geom = Geometry($feature);
  return null;
} else {
  return geom.Z * 3.28084;
An even simpler expression would be
IIf(IsEmpty(geom), null, geom.Z * 3.28084);
KenBuja
  return null;
} else {
