Arcade help with calculated value in Field Maps
2753
7
03-25-2025 06:30 AM
peterverwey_ses
Hi all,
I am looking for some help with a calculated value in Field Maps. My very limited Arcade is letting me down and any help would be appreciated.
Background
  • Using Field Maps for Damage Assessment
  • Feature is DamageAssessment
  • Need to calculate IsHabitable field - values are Habitable, Not Habitable, and Not Applicable
  • Other factors are BuildingType and Damage
Form order sees the following:
  • Select BuildingType
    •  options are Residential and a range of other values
  • Select Damage
    • options are None, Slight, Moderate, Severe and Destroyed
  • Calculate IsHabitable - this is where I need help
Rules:
  • For all BuildingType !== Residential, IsHabitable = Not Applicable
  • Where BuildingType == Residential
    • Where Damage == Severe || Damage == Destroyed, IsHabitable = Not Habitable
    • For all other Damage values, IsHabitable = Habitable
The form element for IsHabitable has conditional visibility for BuildingType == Residential
Questions:
  1. What Arcade code can I use to calculate the result I need according to the above rules?
  2. This is a required field. If I have conditional visibility, will the calculation run if the condition is not met, or do I need to set a default value in the templates with IsHabitable Not Applicable?
The calculated value has conditional Editing allowed with a switch value so users can override the calculation.
AustinAverill
Here is an example. For this, I start with single conditions and return the function based on that. If it doesn't meet the logic of the if statement it passes to the next logic. Finally if all non-applicable or non-habitable conditions are passed, it return habitable.
//handles non-residential buildings and returns not applicable
if($feature.BuildingType != 'Residential'){
    return 'Not Applicable'
//if it is "Residential" will check for damage and return val
if($feature.Damaga == 'Severe' || $feature.Damage == 'Destroyed'){
    return 'Not Habitable'
//if the building is residential and the damage is not severe or destroyed will return this vallue
return 'Habitable'
AustinAverill
return 'Habitable'
AustinAverill
Misspelled "Damage" on line 6 and didn't catch it until after hitting post. 😥
DougBrowning
MVP Esteemed Contributor
I would write it more traditional like this.  easier to follow.
else if($feature.Damaga == 'Severe' || $feature.Damage == 'Destroyed'){
else {
    return 'Habitable'
peterverwey_ses
@DougBrowning thank you. This is how I would think as well.
AustinAverill
Adding the "else if" as statements is definitely probably more technically sound and has a better readable flow. I just didn't do it in my example to really flesh out each logic check as it's own entity for the sake of understanding how the code executes.
peterverwey_ses
@AustinAverill thank you so much for your help.
Turns out I was completely over-thinking everything.
Not only that, I was using string values for an integer based domain. The working code is listed below. Thank you again.
if($feature.Building_Type_General != 0) {
    return 9
if($feature.Damage == 4 || $feature.Damage == 5) {
    return 2
//if the building is residential and the damage is not severe or destroyed will return this value
return 1
AustinAverill
Ahh, yes. Forgetting something is on a integer coded domain will be a hinderance every time! 😂
