Arcade for Creator field
127
Tuesday
FrankHerbert
This one should be easy for most people out there...
I have a Field Maps survey for offline use. There is only one feature layer that I wish to populate during data collection. I have a field called 'Contractor' and I want it to auto-populate the same as the Creator field. Editor tracking is enabled on the target feaure layer.
So in other words, I can record the name of the person collecting the data without worrying about losing the info if editor tracking is disabled.
I have tried the following:
$feature.Creator
Text(GetUser().username)
$user.username
And a few others. Most of them return the Creator field inside the arcade expression preview pane, but then they fail inside Field Maps. I can do this easily in QuickCapture but for some reason, Field Maps won't let me.
AlexHogan
Hi @FrankHerbert
I just tested the following Arcade expression and this works offline
var userInfo = GetUser($layer);
return userInfo.username;
Information like the FullName does look like it requires an online connection though,
Let me know if you have any other questions about this one
Alex
AlexHogan
Hi @FrankHerbert
Alex
FrankHerbert
This works 🙂
Thank you Alex.
