Turn track collection on/off from Map
1285
07-13-2022 05:30 AM
Status: Already Offered
Labels (2)
Mitch_East
Presently, users have to turn tracking on/off from the Field Maps home screen as seen below. It would be useful if there was a similar switch within each Map so that users did not have to exit a map to turn on/off the tracks.
As an example, our organization has a workflow where staff navigate to 'Go To' points and are required to record the path using Location Tracking. We do not want tracks outside of the navigation between points and it would offer more flexibility if the tracking could be turned on/off from within the map.
3 Comments
ChrisDunn1
Hi  @Mitch_East - you're in luck. At the top of  the map screen there  is a GPS Banner which displays the GPS accuracy. If you tap on that you will see the toggle to turn Location Sharing on or off from within the map so you won't have to go back out to the browse maps screen to  change it.
I hope that helps!
Chris
Mitch_East
@ChrisDunn1 Awesome! Thanks for pointing it out.
JustinColville
