Sequential values for Field Maps
3742
11-03-2021 03:15 PM
GuyWeerasingheAWE
Hi there
I would like to be able to generate sequential numbers for each "inspection" my team makes in the field. It would be preferable for this value to be automatically generated in a format of my choosing (ie. I have the option of the number being generated with 3 digits (ex. 001, 002, 003) or with a prefix attached to it (ex. Grp001, Grp002).
I've seen this discussed in the Field Maps Question section (but on the subject of Contingent values), but based on the the comments, it doesn't appear to yet have been deployed in Field Maps (just in Pro) - there is some mention in the May 2021 video that contingent values might be over the horizon, but wanted to check if this functionality could be used for generating sequential numbers.
Solved: Contingent values for a hosted feature layer in Fi... - Esri Community
4 Comments
cbp-geus
We have the same request from our field geologist. They need a unique sequential sample number, with the possibility of a prefix, like the locality name or personal initials. This is crucial when taking hundreds of samples remotely in coordinated groups and offline.
StefanArvidsson
We have the same need too in our organisation.
GuyWeerasingheAFF
Hi all
just following up on this a little while down this journey (changed department names and thus different login) - I ended up using a modification from this entry and it seems to work ok (so far)
only caveat is that it can’t work on AGOL offline maps but does work on offline maps downloaded to your device
https://community.esri.com/t5/arcgis-field-maps-questions/field-maps-offline-map-arcade-calculation/...
GuyWeerasingheAFF
This seems to work for me - operating with a new ID due to change in department name and licenses
https://community.esri.com/t5/arcgis-field-maps-questions/arcgis-fieldmaps-form-calculate-expression...
