Please provide the functionality in ArcGIS Field Maps to support editing capabilities like: Snapping, Tracing, Split, Generate Hole feature, etc
6169
12
09-08-2021 10:46 AM
TikaAdhikari
Please provide the functionality in ArcGIS Field Maps to support editing capabilities like: Snapping, Tracing, Split, Generate Hole feature and etc.
Tags (1)
12 Comments
Ewout_de_Graaff
Totally agree, we use to copy the attributes from one line to create two of them instead of splitting them. Very tedious work now. So splitting would be great functionality for us.
Please add COGO functionality too. This will make it possible to translate field measurements to features on the map.
MTarvid
We would also like to have these features added to Field Maps for editing purposes.  These would increase the accuracy of the data collected, and increase the efficiency of the data collection and editing processes.
MiraManiyar
For land use mapping, we urgently need the ability to split polygons in field maps. In this way we could collect topologically correct data in an effective way.
LindseyStone
I agree having the ability to do a split in Field Maps would save a lot of work between Field crews and office crews.  We sometimes have part of a line on a service replaced so they either have to drawn in a brand new line  so the entire lines attributes are not updated or call into the office and tell us where to split it and then they can update the attributes on the appropriate section.  If they could just split right in the field and update accordingly it would be a huge timesaver.
SkógræktarfélagEyfirðinga
For mapping different vegetation we urgently need the split in Field Maps. The lack of functionality in field maps is making us go back to paper and pencil and then on a later occasion map out features in ArcGIS pro. It would really safe time to have the split in Field Maps.
Bjarni
BjörnTraustason
It is very important to have the split function for polygons in Field Maps. Reshape or Auto complete polygon would also be very helpful working with polygons in Field Maps. It will be a huge time saver both for the field crew and the post processing work at the office will be very little or none. When mapping different and often complex boundaries between vegetation classes, it would be very good to have possibility of pen mapping.
SigmundurHBrink
I totally agree with everything that´s been written above.....
I have been using mobile versions of ArcGIS since 2008, ArcPad, Collector e.t.c. Not having the option to split, reshape and auto complete is giving me and our teams a lot of problems. It it quite embarrassing to know that our field workers are actually starting to use print outs again, drawing on them with paper and then do the mapping when back in office. Here in Iceland we do not have the privilege  of 3, 4 and 5 G mobile connection everywhere. We need to be able to create our custom maps, download them and actually do mapping with field maps. Then with "Split", "Reshape" and "AutoComplete polygons". Please make these options available to us.
SimonRoy1
We also need to split polygons and lines to modify vegetation control areas under power lines.  Actually, areas are digitalized in the office using photogrammetry tools.  Field technicians are then going to the field to validate and adjust the polygons.  Actually, they use the drawing layer to identify what needs to be adjusted and they make the modifications back in the office using a Web AppBuiler App or with ArcGIS Pro, which is not efficient at all.
MarkYoung
Hi all. I came across this issue yesterday. I know surveyors can snap in Field Maps when creating features but this does not seem to be possible when editing an existing feature's geometry? Would also be a massive benefit if features could be traced to improve efficiencies in the field
