Multiple choice option in Field Maps
36257
50
10-06-2021 08:30 AM
Status: Implemented
ZoevdbAT
I'd like to have a multiple choice option in Fieldmaps. The current version of Field Maps (Oct 2021) has  limited options for data collection. When collecting an attribute value I sometimes need people to fill in multiple values form the same domain list. I'd like them to be able to select multiple values from the combobox or radio buttons.
I'm hoping this function will be added with the new function of creating elements form scratch (kinda like the different options in de survey123, preferably the Multiple Choice) but also not like that, because I need them to use my domain values and not create a new field.
Does anyone have a smart workaround for this in the meantime?
50 Comments
ZRex
@Woodpecker  You are a genius, thank you!!!  This is much better than having multiple switch columns.
Jessy_Paquette
Hi All,
I am trying to implement @JustinReynolds method in one of our forms. I was able to populate the list and clear it, but the editable expression does not work. I am trying to find how to get the Conditional visibility field, but I can't.  There is the visibility option, but when I put the code here, it just hides the field except if I select the Manual Entry. Maybe form UI changed since the time he posted his solution.
Thanks for the help!
Jessy
HannahBee
Also would be very beneficial for inspecting-type forms we have rather than a "explain more in text box" option which requires the user to then enter freehand text. It seems this has been brought up 5 years ago. What's the hold up??
andeb31
bump
Jeremy_Z
It's coming, it'll be here soon.
Erwinvan_Veen1
@Jeremy_Z thanks for sharing. Took long enough!
MitchellGrafstein
@Jeremy_Z  - Midterm finally became near-term, thank you for sharing.
KenPearrow_Camas
@Jeremy_Z  -Thanks for sharing the road map.  And I'm glad this functionality is coming sooner than later.
ChristopherBowering
Maybe the functionality will make its way to Enterprise before I retire...!
JeffShaner
