Linear referencing and continous measuring
1106
01-05-2023 06:32 AM
Status: Open
AndreAvolson
The implementation of linear referencing in field maps is very close to our needs. What's missing is being able to measure continously, that is to see the section numbers increase while you move along the reference line, and - at the same time - see the distance perpendicular to selected line.
Our lines also have heights. The height corresponding to the section your at (or want to be at) is very interesting, and should be an easy calculation.
It would also be nice to measure the same data with point-and-click on screen. That is, the needle you pin-point will have information about section number and distance from line (perpendicular).
Use cases for these ideas is to be found in road construction projects and pipeline projects by those who do the construction work. I've read some earlier ideas about differing if you're left or right of the line. We're used to that when youre left of the line, distance value is negative, and positive if you're on the right-hand side.
2 Comments
JayRiester
Andre,
Hi, on a similar note we have asked the Field Maps development team for a similar enhancement when Staking Out along a line. Give indicators of positive/negative, Left or Right or a Red Light/Green Light indicator if you are on the line within a certain tolerance or out of tolerance. Especially if your have CM or 4 inch accuracy GNSS Receiver. Our USE Case would be for crews in buried utility markets, forestry/timber and large property/land management use.
AyanPalit
@AndreAvolson Thanks for using linear referencing in ArcGIS Field Maps and documenting these enhancement ideas. Please add some screenshots, examples to further illustrate the use cases.
Follow these Submission Guidelines to submit your idea for the community to vote on!
