In Forms for Field Maps, be able to choose from Code instead of Description for a Coded Domain.
1028
06-05-2024 06:14 AM
Status: Open
CarolineLindhe
When building a form in Map Viewer or Field Maps Designer that will be used in Field Maps I would like to choose if the Code or the Decription of a field that has a Domain will show for the mobile worker.
I've tried to use Arcade and DomainCode for the field in the form but it looks the field.
Preferably a simple check box in the settings for the field in the form builder.
Another wish I have is that the filtering function in Field Maps would search both in the Code and in the Description Column.
Is there a work around already that someone can share?
