Follow-me function
554
03-17-2026 04:42 AM
Status: Open
AdministratörHolmen
We want a “Follow Me” feature in the map that ensures the user’s GPS position is continuously tracked, even when not in editing mode. The functionality should behave similarly to navigation in Google Maps while driving, where the map automatically adjusts based on the user’s real-time movement.
This means:
  • the map should automatically center on the user’s GPS location
  • the map view should update continuously as the user moves
  • the user should not need to manually reposition the map to find their location
  • the feature should be active even outside of editing mode
  • the experience should feel like live navigation, with smooth and responsive map movement
Purpose:
To improve usability in the field by allowing users to easily stay oriented while moving, without needing to constantly interact with the map.
2 Comments
ChrisDunn1
Hi @AdministratörHolmen ,
Have you tried using the location tool in the map (the button in the top-right corner of the map view)? It has three modes (see the details in part 8 of the help section available here):
  • Default - your location displayed on the map
  • Tap once - the map automatically centers on your location while oriented north
  • Tap twice - the map automatically centers on your location and oriented in the direction you are facing
It sounds like the third mode (tapping on the tool twice) will give you the behavior that you're looking for. If that isn't working how you'd like, can you elaborate on what is missing from it?
LindsayRaabe_FPCWA
I suspect that the problem with the existing functionality is that it behaves slightly differently to most apps with auto location tracking/follow me functions. When in Google Maps or Ozi Explorer for example, the screen moves constantly tracking the users location. In Field Maps though, the screen moves in "steps" for lack of a better term. The user will always be visible in the centre third (approx) of the screen, then the screen will slide to recentre the user as they move towards the edge of the view. You get this constantly move-pause-move-pause effect on the screen as the user travels across the map. I've always found this annoying and suspect it's what the OP is either wishing behaved like most apps, or has mistaken it for not actually being location tracking.
