Enable freehand polygon drawing
24847
45
03-19-2021 12:25 PM
Status: Open
VictoriaTousaw
It would be very useful to be able to draw polygons freehand (like you can in ArcGIS Pro), instead of by adding individual vertices. This would be especially useful when creating polygons that are rounded and require many vertices to properly draw.
45 Comments
Gavin_Leavitt
Adding our use case for freehand drawing, we conduct vegetation surveys from helicopters where being able to quickly and accurately digitize polygon and polyline features is a requirement. Currently Field Maps and Survey123 do not meet our needs as they don't allow freehand/stylus based drawing. We are still entirely reliant on using ArcPad (now many years retired...) for these projects since it contains this feature.
avillamo_bhp
I strongly support this feature request. Our geologists frequently need to map geological outcrops in the field, and the current method of placing individual vertices results in polygons that are overly angular and don’t accurately represent the natural, rounded shapes of these features.
Because many outcrops are inaccessible for walking around, they can't use streaming or GPS tracking to capture boundaries. A freehand drawing tool—similar to what’s available in ArcGIS Pro—would allow them to sketch more realistic shapes directly on the map, improving both the accuracy and usability of the data collected.
This enhancement would be a game-changer for geological fieldwork and other disciplines that require mapping of irregular, organic features.
JoshuaKeeley_NHDES
Yes! Please allow freehand line drawing so lines are recorded to a feature class instead of Markup. My field team of geologists need to draw lines freehand in a way that can be backed up on AGOL. It's too cumbersome and time consuming for many of them, me included, to draw lines vertex by vertex in the field. Some "fair weather days" are 100 degrees, and mere seconds matter when your iPad is giving you temperature warnings and your sweat is dripping on the touch screen. In the office, it's too cumbersome to export every field worker's Markups to get them synchronized and saved. FYI, our cybersecurity protocols prevent device-to-device sharing...otherwise sharing Markups might not need manual exporting. Freehand line drawing into a feature class would save all of us a lot of trouble and only then will Field Maps be absolutely perfect for us. Thank you!
JET_Ramboll
Dear Esri,
PLEASE DO THIS I AM BEGGING YOU
It's possible in web editor, it's possible in Survey123, it's even possible in the markup layer in Field Maps - surely it's not a big ask to implement in our feature layers?
As others have said - this is the #1 roadblock for getting our survey teams going forward with digital data capture as plotting by vertex is painful.
Thank you,
Joe
ElisabethB
Strongly supporting this idea. Our customers doing bird surveys need to sketch flight lines quickly in the field – freehand drawing is the only practical solution for this. ENH-000177224 has been "In Review" for months with no update. Would love to see this move forward.
