Enable/disable Feature Snapping for specific layers
9140
15
04-05-2021 08:53 AM
Status: Open
TravisSizemore
Hi everyone,
Our field crews use multiple reference-only layers in Field Maps and other layers that they collect data with. They find it useful to have feature snapping on, but only want to snap to the features they have created (not to the reference layers).
It would be preferable if there was a way to disable and enable snapping to specific layers within a web map in Field Maps.
Travis
15 Comments
CSDING_GIS
We work with floor plan data in Field Maps. Since annotations are not supported, room labels are fed through a point layer with almost invisible symbology. We would like to enable snapping, because the data that's captured must often follow the floor plan's polylines. But with all the label points, snapping becomes very annoying. Would like to see this implemented sooner than later. Doesn't necessarily have to be configurable on the app, designer (as part of the resource json) would be sufficient.
TD1
@DanielFox1 any update on the ETA? I also need this implemented as user are constantly snapping to other features and not noticing until later.
Nicole_Ueberschär
We also need this implemented as soon as possible. If at least Field Maps would recognize the Map Viewer settings!
wtfineberg
Ability to restrict/limit snapping in Field Maps is a strong need for us as well. I agree that having Field Maps honor the Map Viewer settings would be the most elegant solution.
BrianGray3
There's a way around this. When you're positioning the object, don't lift your finger before hitting Submit. Hit Submit with one finger while holding down on the location.
