Edit calculated fields
454
04-28-2026 02:25 AM
Status: Open
KatieQuantrell
It would be great if fields within Field Maps that are calculated via arcade expressions, could still be set to be editable. (Like is possible in Survey123).
Currently the workaround for this is to add an additional field as a 'override field' with the editing on the main field then becoming active if this override field is set to yes. However this feels very clunky, and as requires extra fields on the forms for users to set.
Be much better to just be able to clear the calculated data/recalculate it directly on the main field.
Thank you
1 Comment
Laura
by MVP Regular Contributor
That's already an enhancement request: ENH-000175483 for web editor, exb, field maps.  You can call support and get your org added to it.
