Copy field values from first selected feature in Edit Multiple
567
02-26-2021 05:31 AM
Status: Open
Ewout_de_Graaff
What I really miss in Field Maps compared to the asset management software that I want to replace with Field Maps is the possibility of copying field values to another feature. Until now it is only possible to copy a feature as geometry.
The use of "Edit multiple" does not quite meet the need here. It would be wonderful if in the Edit Multiple function a choice would be made for the values of the first selected feature per field. In addition, it would be absolutely perfect if there was a check box with which this is set on all editable fields.
