Arcade Form Calculation return Dictionary
1438
07-22-2022 05:50 AM
Status: Open
ManoSadeh
Arcade Form Calculation profile return types are: Date | Number | Text. It will be helpful to also return a Dictionary type. This could be used for ArcGIS Runtime apps, in case a few attributes can be calculate in the same expression.
Thanks
1 Comment
JustinReynolds
I had this same thought about being able to return more complex objects (dict, feature, geometry, etc.), but it might be weird to have a dictionary return type without a matching dictionary field type.
Arcade supports returning a JSONified string and then a way to read it in as a dict with the fromJSON() function.  I use this approach a lot when fetching data from other layers as using featureSetByAnything can be very costly, so if I need multiple fields to fetch data from the same dataset or feature I just delegate the task to a single field that returns a jsonified string and use the result of that field as an in memory lookup resource.
Building it looks like this...
//ASSIGNED TO
//  $feature["rsrc_service_info"]
function getServiceInfo() {
    var serviceNumber = $feature["service_number"];
    var serviceNumberDesc = DomainName($feature,"service_number");
    // var serviceNumber = "'02081600.1658"; // TEST VALUE
    // var serviceNumberDesc = "'02081600.1658 (Placeholder)"; // TEST VALUE
    if (!IsEmpty(serviceNumber) &&
        Find('Placeholder', serviceNumberDesc, 0) == -1) {
        serviceNumber = Replace(serviceNumber, "'", "");
        var sql = "service_number LIKE '%" + serviceNumber + "'"
        var fields = ['service_number', 'service_status', 'task_id',
                      'keyword_id', 'permit_id'];
        var mapLayer = 'Service_Orders_Resource_Table'
        var fset = FeatureSetByName($map, mapLayer, fields, false);
        var ffset = Filter(fset, sql);
        for (var f in ffset) {
            break;
        if (!IsEmpty(f)) {
            console('Building jsonText');
            json = '{"service_number": "' + f.service_number + '", '
                  + '"service_status": ' + IIF(IsEmpty(f.service_status), 'null', '"' + f.service_status) + '", '
                  + '"task_id": ' + IIF(IsEmpty(f.task_id), 'null', f.task_id) + ', '
                  + '"keyword_id": ' + IIF(IsEmpty(f.keyword_id), 'null', f.keyword_id) + ', '
                  + '"permit_id": ' + IIF(IsEmpty(f.permit_id), 'null', f.permit_id) + ''
            console('JSON Length: ' + Count(json));
            console(json);
    } else {
        console(pad + 'Service Number is null or placeholder; return empty json');
    return json;
//START HERE
var pad = '>>> ';
var json = '{}';
return getServiceInfo()
And utilizing it looks like...
//ASSIGNED TO
//  $feature["service_keyword"]
console('Set Service Keyword')
var pad  = '>>> '
var key = 'keyword_id'
var value = Null;
var json = $feature["rsrc_service_info"];
// var json = '{"service_number": "02081600.1658", "keyword_id": 83880}'; // TEST VALUE
if (!IsEmpty(json) && json != '{}' && Find(key, json, 0) != -1) {
    var dict = fromJSON(json)
    value = dict.keyword_id
console(pad + key + ': ' + value)
return value;
