Add a function to get the current field's value within the Form Calculation Arcade profile
3260
07-14-2023 02:21 PM
Status: Open
Gavin_Leavitt
I would like to be able to get the current value from a form input without having to call the field by name when doing a calculation within Field Maps Form Calculation profile.
Take the following example that is calculating on the form input "DateTimeCompleted":
var current_datetime = Now()
var f_name = "DateTimeCompleted"
var exist = $feature[f_name]
if (!IsEmpty(exist)){
  return exist
return current_datetime
Instead of calling "DateTimeCompleted" it would be useful to use a contextual function to get the existing value of from the field that is getting calculated.
This would make it easier to write generic Arcade functions that can be quickly re-used.
3 Comments
JustinReynolds
Hey Gavin,
To clarify, within the Form Calculation and Form Constraint Profiles, are you seeking a profile variable similar to something like $self and by extension $originalSelf?
Gavin_Leavitt
@JustinReynolds Yes, I was not clear on the correct terminology for this idea, but profile variables of "$self" and "originalSelf" are exactly what I am asking for.
MarkGo
These generic variables would immensely help with updating a group of fields based on a status flag. I don't want to have to create expressions for each field (there are about 2 dozen of them), when the same transformation needs to happen to each field.
Having $self would make this one single expression to handle all of the fields.
