Turn off "address" of feature selection?
849
09-14-2018 11:26 AM
by Anonymous User
Not applicable
I have a map with a point layer of service addresses (points). When I select one of those points in Explorer it returns an "address" below the primary display field in the results pane. Can this feature be turned off or switched to show coordinates? I suspect it is a geocoded address, however, it is confusing because it is often not the real world address.
The behavior in Collector shows coordinates below the primary display field in the selection details pane.
AlexJohnson3
Matt,
Did you ever find out a way to do this?
by Anonymous User
Not applicable
No. I have not. I'll submit as an idea.
