Import Shape
3052
11-22-2011 05:12 AM
AlbertoCumbrera1
Good.
I've been trying to import a shape to ArcGIS Online on several occasions and do not let me. Send me the following error message:
Failed to import shapefile.
Invalid Shapefile: SHP file missing
I created a folder with these four files:. Shp,. Shx,. Dbf, and. Prj. After that it became became a zip file. Not because I can import it.
thanks
MikeRudden
There is not enough information here to diagnose your problem. If possible could you post your .zip file and we will take a look for you? If not then i'd recommend reading through the help on Importing Shapefiles, and specifically the tips section at the end.
Mike
AlbertoCumbrera1
I attached an example of shape.zip send me buggy when import it.
thanks
MikeRudden
thanks
This shapefile does not import as the zip file is badly constructed - it contains a sub folder called provcnt2 which then contains the files. Create a new zip file without the subfolder and the import will work just fine.
(Una otra cosa mas - Hace dos años viajé por Panama - es un país muy interesante. Visité algunas de tu puntos, incluido Bocas del toro y David.)
Mike
AlbertoCumbrera1
Mike thank you very much, now if the import works.
(If Panama has good beaches and excellent tourist spots)
