Documnet Invalid or Corrupt
956
07-13-2011 07:03 AM
PRAVINMATHUR
Cannot open a map that is shared. Get a invalid or corrupt error message. Here is the link - http://explorer.arcgis.com/?open=415d314f2c6c461d9d6a6fe614285832
TIA.
NickBlack
Hi Pravink,
Unfortunately we have a known issue in Explorer Online loading a map where the feature attributes contain backslashes. We are aware of the problem and will be releasing a fix in the next release, slated for August.
Until then, I've fixed up, and shared your map without the backslashes. See here:
http://explorer.arcgis.com/?open=09c698abb1f145e5bbd12b520cf3f14e
Let me know when you have saved the map to your account, and I will delete it.
Apologies for the inconvenience.
-Nick
PRAVINMATHUR
Thanks Nick. I will be on the lookout for the Aug release.
btw, any suggestions for adding images as an attribute inthe shp file till then.
NickBlack
Hi again,
You could try hosting your images on a web server- and then include hyperlinks in the shapefile attributes rather than UNC paths.
Regards,
Nick
