Document Invalid or corrupt
5220
23
12-22-2011 03:14 AM
LeLystad
Dear Esri,
We have a problem with opening our created GIS map. When we try to open it, we get the message: the document is invalid or corrupt. D5Lelystad had unfortunately the same problem.
We allready made the map public. Hopefully Esri can fix this map as well. The map ID is ba20abcd844849aaa61159580853b4b7. If you need more information please tell us.
Thank you very much!
C1Deventer- Kimberly
AndyMacDonald
I have created a repaired copy of your map. Please open this map and save is as a new map in your account:
http://explorer.arcgis.com/?open=4e11493a3c8640f6a8af7bd67e999967&extent=682082.920532005,6843136.41...
We are working on resolving this issue.
Andy
LeLystad
Thank you for fixing our problem.
I clicked on the link you sent me and i had saved it on our account.
Now we can further..
Thanks for your help
C1Deventer-Kimberly
DougShidell
I just experienced the same problem with a document created by a member of our group. The document is shared with a group, but not public. The document number is b1a6c9dc54304050bd5967a8537a3cc6.
Can you help?
Thanks.
LeLystad
Could you please also fix our GIS document the document ID = 83cde3432ab04e27919695ad16769ffc
Thankyou!
Emily Beckwith
ShellyGill2
I have removed a geometry which had been created incorrectly, and made a copy of this map:
http://explorer.arcgis.com/?open=788fbed57c0c451bb83a7eed0be441c8&extent=459202.421000875,6803679.80...
Let me know when you have saved back your own copy of this map and I'll delete it.
(The problem was caused by a bug, not anything you did incorrectly. We have a fix for this bug which will be in the next release of ArcGIS Online, so hopefully you wont encounter this problem again).
ShellyGill2
Sure, if you send me an invite to your group, I will try and fix it - my username is sgill.
(I cannot access any maps unless they're shared publically, or shared with a group of which I'm a member).
DougShidell
I have added you as a group member. Thanks for the help.
ShellyGill2
Thanks for that - same problem as above, so again I have removed a geometry which had been created incorrectly (it was an 'Existing Bike Trail' feature number 117), and made a copy of this map - I saved it back to the same group, as <original name> - Copy.
DougShidell
I've saved it and shared it with the group. Thanks again.
