When I use ARCGIS Explorer online and I have multiple pins in the exact same location, I can't scroll through the pins like I can in ArcMap Viewer Online. Because each pin has about 8 different attribute fields, it isn't appropriate to merge all the pins into one which would be OK if there was only one or two attributes.
Why is the little scroll button in the ArcMap viewer but not in ArcMap explorer? Am I missing something here? It seems to be a very basic and necessary feature as when I am zoomed out and trying to click on a pin it will only click on the same pin each time.
I may have to resort to using ArcMap viewer instead of explorer.
Thanks.
