Classify Features Manually
2671
08-08-2011 12:44 PM
AmberT
I am trying to symbolize my polygon data by using a specific range of values.  As far as I can see, ArcExplorer Online does not allow you to manually change the value range ("Classify using"), only the label.  Is there a way to classify using color and manually select the ranges instead of Natural Breaks, Standard Deviation, Quantile, and Equal Interval?
Amber
MikeRudden
The answer to your question is no you can't.  I guess one workaround would be to symbolize by unique values and change the unique value colors to match the range you are interested in (although of course the number of unique values will determine whether this is practical or not).
If you'd like to see this as a future enhancement to the product please record this as a request on the ideas website under the ArcGIS Online section.
Mike
AmberT
Thank you for getting back to me Mike,
Although that work around technique works, it would not look that great in the legend.  I wanted the map to mimic our static map that we have on our website.  However, the map on our website does not give our readers the exact number, where as an interactive map would give an exact number when they click on a location.  I�??ll add the suggestion to the �??suggestion box.�?�
Thank you for your time,
Amber
