ArcGIS Explorer Graphic Card Recommendation?
3800
07-30-2010 06:44 PM
JerryGarcia
ArcGIS Explorer requires a good graphics card.  You can test to see if your graphics card is good enough using the ArcGIS Explorer tool, "test graphics card".
I have a client who needs a recommended graphics card.
Does ESRI post a minimum or recommended graphics card requirement on the web?
If not, what is the recommended graphics card specs to use ArcGIS Explorer efficiently?
Thanks!
MichaelBranscomb
Esri Frequent Contributor
Jerry,
ESRI don't recommend any specific graphics cards. The recommended spec is to have a 24-bit capable graphics accelerator with at least 256MB dedicated video card memory (rather than shared system memory) which supports OpenGL 2.0 or higher. The system requirements checked mentions Pixel & Vertex Shader 4.0 if you can get that level of detail from a graphics card fact sheet. If you're planning a lot of 3D work in Explorer then you'll want as high a spec as possible on the above recommendations. I've always had NVidia cards in my office laptops and enjoyed a good experience in ArcGIS Explorer but we do have staff using other brands.
Regards
Mike
JerryGarcia
Thanks for the reply and the info!
Where did you get this info?  Is there a web site?
Maybe a better question is: What are the specifications that AGX tests when using the graphics card tester?  What minimum specs does it use to determine good or bad?
MichaelBranscomb
Jerry,
The graphics card spec info came from the system requirements website for ArcGIS Explorer: http://wikis.esri.com/wiki/display/agxpsr/ArcGIS+Explorer+System+Requirements.
Regarding the graphics card test - this test runs in the 3D display mode and animates the globe for approx 30 seconds to determine the frame rate, in frames per second. I advise running it several times to determine an average for your machine.
>30 frames = Excellent
>15 frames = Good
<15 frames = Poor
(http://webhelp.esri.com/arcgisexplorer/1200/en/test_graphics_speed.htm)
If your client would like to do a lot of work in 3D within ArcGIS Explorer then I would certainly advise looking at the recommended spec rather than the minimum:
- CPU = >2.4 GHz (although that's based on a baseline Intel P4 / Xeon whereas the newer, multi-core processors have lower clock speeds but are usually rated higher e.g. my Intel 2.4 GHz Core2Duo seems to be rated at 4GHz)
- RAM = >2GB
- VIDEO = >256MB with Pixel & Vertex Shader 4.0
- DISK = >1GB free
Regards
Mike
JerryGarcia
Mike:              Thanks!
