ArcGIS Explorer requires a good graphics card. You can test to see if your graphics card is good enough using the ArcGIS Explorer tool, "test graphics card".
I have a client who needs a recommended graphics card.
Does ESRI post a minimum or recommended graphics card requirement on the web?
If not, what is the recommended graphics card specs to use ArcGIS Explorer efficiently?
Thanks!
