Search (VB.NET)
2931
12
03-30-2011 08:05 AM
BrianLeroux
I am having an issue searching using VB.NET. I am using the following to search a file number but it needs to be entered exactly as in the table.
Dim SrchStr As String = "File_Numbe = " & SrchTxt
I want to be able to enter a patial number and give me the matching results. I have tried the following with no success. Any ideas?
Dim SrchStr As String = "File_Numbe LIKE % " & SrchTxt & "%"
Dim SrchStr As String = "File_Numbe LIKE '% " & SrchTxt & "%'"
DonnaBest
Hi Brian -
Sorry not to respond sooner - I was gonna test a little but haven't gotten there.  I'll tell you about the next item I'm struggling with in a sec (smile).
A few random thoughts on your issue - I may be missing what you're saying -
1)  So is the File number a text field?  I used the UCase in a variable to set the case for the textbox input string, then referenced the variable in the search criteria.  - we may be doing this a little differently.  I'm using Table.OpenShapefile("path") which may be causing me more troubles.
2)  If you have to convert (CAST is convert yes?),  can you use the same method - converting in a string to a variable?
3)  If the file number is numeric, would >+ or <= in the search string help?
My current headache:   I need to sort on multiple columns in my datagridview.  I'd like the datagridview to only have a few fields from the table and try to sort them that way, but I can't seem to get there from here.
Not sure I'm any help, but misery loves company, yes?
Happy Monday
Donna
BrianLeroux
Donna,
The file number is text as it may contain letters. We just call it a number internally as it has always been called that. I am using a variable in the search and can do a UCase there no problem. My issue is that i need to convert the data i am searching through to UCase also and can not find a way to do that. The reason i need to convert is because this tool I am devoloping will not just search my file numbers but any field from any feature I have selected and that may include different cases for text fields.
looking at datagridview.fill I do not see any way to specify the columns. I would actually like to do this as well and was planning on looking into it further. I will let you know what i find.
DonnaBest
Brian -
I've found that in order to sort multiple columns I have to use IComparer and found a function.  But it only works with String fields, so I have to figure out how to Cast or convert the value of the two numeric fields I want to sort to strings - you've had the same problem yes?
Meanwhile, I had a hard time finding how to specify the fields with the datagridview autogenerated.  Haven't looked into setting autogenerate = False.  Will let you know what I find as well.
Donna
