Search (VB.NET)
2878
12
03-30-2011 08:05 AM
BrianLeroux
I am having an issue searching using VB.NET. I am using the following to search a file number but it needs to be entered exactly as in the table.
Dim SrchStr As String = "File_Numbe = " & SrchTxt
I want to be able to enter a patial number and give me the matching results. I have tried the following with no success. Any ideas?
Dim SrchStr As String = "File_Numbe LIKE % " & SrchTxt & "%"
Dim SrchStr As String = "File_Numbe LIKE '% " & SrchTxt & "%'"
MargoBlosser
This has worked for me:
Dim whereClause As String = ("Situsall LIKE" + Space(1) + "'" + Tboxsearch.Text + "%" + "'")
Best Regards,
Margo
BrianLeroux
Thanks Margo. Unfortunately it did not work.
DonnaBest
Hi Brian -
Did you find a way to do this?  I have a similar situation and thought Type Ahead functionality might do the trick..  so I'm investigating how to do that?
I know your post was a while ago, thanks for your time
Donna
BrianLeroux
Donna- Actually this thread started yesterday. I think you were looking at my "joined date". Anyhow, I have still not found a solution and am still investigating.
DonnaBest
Brian -
Hope this helps..it worked for me.  Not much different from Margo's so I'm curious to see if it works for you as well..
             Dim StreetString As String = UCase(StreetSearch.Text)
             Dim BuildTable As Table = Table.OpenShapefile("C:\Maps\ArcGISExplorer\Intersections.shp")
            searchFilter.WhereClause = "STREET like'" + StreetString + "%'"
(I Was at your 'join' date - but I see where to find the post date now - thanks!)
Donna
BrianLeroux
Donna-
That did not work for me. It allows me to search for an exact match put does not work for a partila match. ie- I can search for 1234 and find the file but if i try 12 it does not find 1234.
Thanks.
Brian
BrianLeroux
Donna -
Good news. It did actually work. I had the old add-in stuck in cache and my updated code didn't go through.  Thanks for your help..
searchCriteria.WhereClause = "File_Numbe LIKE'%" & SrchTxt & "%'"
Try
    Dim rows As RowCollection = layer.Table.Search(searchCriteria)
DonnaBest
Oh that's great!   Reminds me to go read up a little on cache - so win-win!
Donna
BrianLeroux
So my next problems with my Search Add-in..
1) The search is case sensitive and I would like it not to be. I was going to use UCase on the search string and the column data. However, since I am using table.search there is no select statement to use UCase on the column I am searching.
2) I would like to use LIKE in the where clause for my columns formatted as numbers. That would mean i need to CAST them as a string. As in the case of the issue abouve, since there is no select statement I can't perform a CAST on the field I am searching.
Any ideas are appreciated.
