Query layer using another layer (VB.NET)
1280
03-23-2011 12:05 PM
BrianLeroux
I am looking to build off of the Query Features sample. Instead of drawing a polygon so select, I am looking to use the polygons inside a shape file. The issue I am having is I am not sure how to identify the contents of a shape file as a point, line, or polygon. I can identify the layer type with the following but not the shape types.
For Each item As MapItem In fold.ChildItems
            If TypeOf item Is Layers Then
Any help is appreciated.
AndreiIvanov
Brian,
to identify the shape type of the layer you need to do it via Table class. Table class has GeometryType property that from the help "Gets the type of geometry that this Table is capable of storing". If you need further help, let me know!
BrianLeroux
I can't get this layer by query code working. Any help is appreciated.
Dim points As Table = tvwMapItems.SelectedNode.Tag
        Dim poly As Table = tvwMapItems2.SelectedNode.Tag
        'Create a List to store ObjectID's
        Dim objectIDList As List(Of Integer) = New List(Of Integer)()
        'Loop over each  area and perform a spatial query to find points
        For Each polyArea As Row In poly.GetRows()
            Dim polyAreaShape As Geometry = polyArea.Geometry
            Dim foundPoints As RowCollection = points.Search(New Filter(polyAreaShape, FilterSearchOptions.Intersects))
            For Each rw As Row In foundPoints
                objectIDList.Add(rw.ObjectID)
        ' create the table binding adapter and fill it
        Dim tableBindingAdapter As TableBindingAdapter = New TableBindingAdapter(points)
        tableBindingAdapter.UseColumnAliasNames = True
        tableBindingAdapter.UseCodedValueDomains = True
        tableBindingAdapter.Fill(objectIDList.ToArray())
        ' display the results
        Dim resultsForm As QueryResultsForm = New QueryResultsForm(tableBindingAdapter)
        resultsForm.ShowDialog()
